Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
JD 1020 3 cyl gas, removing head
Tim Daly
06-12-2012 18:52:08
Have all the bolts out except for the two that are between the valves, under the valve cover. Is there some special wrench that is made to fit in there? The bolts are almost directly under the horizontal arm that the valves ride on.
06-13-2012 06:35:32
 Re: JD 1020 3 cyl gas, removing head in reply to Tim Daly, 06-12-2012 18:52:08
You need to remove the rocker arm assembly.
Tim Daly
06-13-2012 08:01:50
 Re: JD 1020 3 cyl gas, removing head in reply to Maark, 06-13-2012 06:35:32
Thanks. Figured out this morning that the fellow who told me differently was not correct. Shall probably take it all apart, get the head machined, then get someone good to put it back together and set the valves properly.
