Topic: Battery doesn't charge
[Return to Forum]
| Author |
[Modern View]
| JDawg
06-09-2012 05:03:17
63.135.182.16
I have a '63 Ford 2000 that has had a 12 volt conversion, and the battery discharges while running. I have wired and rewired by different reccomendations and still have the same problem. I have always had to disconnect the battery when it's parked because it drains then too. The original 12 volt conversion had a Chrysler alternator and Voltage Regulator, I have changed over to the GM alternator and done away with the voltage regulator and rewired the whole charging system. I have apparantly done something wrong, can anyone give me any advise? |
[Reply] [No Email] | |
| soundguy
06-14-2012 10:55:34
173.104.111.55
Re: Battery doesn't charge in reply to JDawg, 06-09-2012 05:03:17
| | ditto what the others said.. we need your wire diagram. you must be leaving something powered like #1 terminal.. OR the alt is bad.. |
| Dave Sherburne NY
06-10-2012 06:34:41
50.48.54.226
|   Maybe this will help. The diode from Radio shack is real cheap Taken from a previous post by BOB this is how I did my Oliver 88 |
| Jon Hagen
06-09-2012 10:55:14
69.26.17.61
| | With the Delco internal regulator alternator, following the wiring diagram in the link below should help you wire it correctly. If it kills the battery when you shut it down, sounds like your #1 alt wire is connected to constant power, and is not turning off with the ignition switch as it must. Also, it showing a 20 amp discharge while running, MAY be a discharge, or really a charge if the tractor was switched from pos ground to neg ground without switching the wires on the ammeter from side to side (post to post). If the ammeter is connected wrong for the battery polarity, it will indicate a charge as a discharge. One way to determine that is to switch on a load with the engine stopped(lights, ignition etc.) If the ammeter moves to discharge when the load is switched on, then the ammeter is wired correctly. If it moves to the charge side, then it is reading backwards and needs the ammeter wires switched from post to post to make it read correctly. |
| JMOR
06-09-2012 05:31:47
72.190.9.193
Re: Battery doesn't charge in reply to old, 06-09-2012 05:03:17
| Quoting Removed, click Modern View to seeIF I knew how you have it wired, I could likely see the problem, but as one old fart likes to say, 'I don't have a crystal ball'........got a diagram of your wiring?? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
