Ford Detxa Oil pressure sending unit?
My tractor does not have the oil pressure warning light on the column nor can I find a sending unit on the engine. Can someone tell me where the unit is or should be and what it looks like. A picture would be helpful.
Gene
NO, I do not have a pressure guage. i understand it should have a warning light on the column underneath the steering wheel along with heat guage and charging light.
Gene
You should place your request over on the Ford forum. You will get more responses over there. Hal
I think Ford Dexta had Perkins 3 cylinder diesel.
If so, the sender unit is screwed into the block, to the rear, on the left hand side, more or less under the fuel filters.
