Yesterday's Tractor Co.
Shop Now View Cart
Re: engine block reconnection to clutch housing mf65
06-06-2012 04:53:26
Try backing it off an inch then bring it back turning the crank as you go. If you have it too tight it can't slip to find the right alignment. Are you sure that they are aligned in the same direction? Often the front is a little lower than the back, and they can't go together if they are not in the same plane. you may need to put the tires of the moving end up on boards.
