Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Topic: Re: engine block reconnection to clutch housing mf65
[Show Entire Topic]  [Return to Forum]
welding man
06-05-2012 19:53:53
76.9.225.76
2 stage clutch? If so,you have 2 set of splines to line up . Did you replace the pilot bearing. Did you check to see if it fit the shaft before installing in the flywheel. Did you check the clutch discs on the splines before assembly. Do you have alignment pins screwed into the transmission housing to help line everything up. Put the PTO in ground speed and turn the shaft. Nothing to it after about two or three clutch jobs a month for the last 30 years and I never use a pilot shaft, just eyeball it.
[Reply]   [No Email]
rich o
06-06-2012 14:35:00
66.220.233.8
 Re: engine block reconnection to clutch housing mf65 in reply to welding man, 06-05-2012 19:53:53
welding man, good advice, backed it off visually lined up splines and grooves, used longer bolts to act as guides walked it in slowly, but with only about a pinkys width left ,heard a cracking sound and could no longer turn the crank. backed it ann off and pulled the block assembly away and found that i cracked the clutch plate, what a mess, i did not want to disassemble the clutch, you sound as though you have some experience under your belt, what do you figure now, is it time for me to find a pro to bail me out?
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
