TractorLinks.com
Restoration & Repair Tips Board
Re: engine block reconnection to clutch housing mf65
Gene Davis (Ga.)
06-05-2012 19:28:13
Did you install the clutch disk in the correct orientation? Some are marked,"this side to flywheel". The splines can go in correctly, but the shaft will hit the disk if in wrong Also are you sure the splines are lined up in the engine part? Try putting the transmission in gear and jacking up a drive wheel and see if it will turn if it turns the splines are not engaging. also,did you use a pilot shaft to line it up. Make sure the pilot bearing or bushing is on corretly
