TractorLinks.com
Restoration & Repair Tips Board
Ford Detxa Oil pressure sending unit?
Gene Stephens
06-02-2012 19:39:33
My tractor does not have the oil pressure warning light on the column nor can I find a sending unit on the engine. Can someone tell me where the unit is or should be and what it looks like. A picture would be helpful.
Gene
El Toro
06-03-2012 03:46:40
 Re: Ford Detxa Oil pressure sending unit? in reply to Gene Stephens, 06-02-2012 19:39:33
Do you have a pressure gauge? It should have the gauge or or the light. Hal
Gene Stephens
06-03-2012 05:06:28
 Re: Ford Detxa Oil pressure sending unit? in reply to El Toro, 06-03-2012 03:46:40
NO, I do not have a pressure guage. i understand it should have a warning light on the column underneath the steering wheel along with heat guage and charging light.
Gene
Bob from Australia
06-07-2012 23:05:58
 Re: Ford Detxa Oil pressure sending unit? in reply to Gene Stephens, 06-03-2012 05:06:28
I think Ford Dexta had Perkins 3 cylinder diesel.
If so, the sender unit is screwed into the block, to the rear, on the left hand side, more or less under the fuel filters.
El Toro
06-03-2012 06:50:04
You should place your request over on the Ford forum. You will get more responses over there. Hal
