TractorLinks.com
Restoration & Repair Tips Board
Re: How do you remove a bering lock on 489 New Holland Mo...
Slowpoke
05-25-2012 21:45:07
I just removed a pillow block and bearing on a Sidewinder mower. That's the mower that uses the PTO to turn a pneumatic drive tire which in turn drives the mower blades. I thought the lock collar was part of the bearing, but it is a separate part. It has an Allen set screw and a blind hole about an inch apart. I used PB Blaster a few days ago but the Allen remained stuck. Someone posted awhile ago that a few blows with a flat nose punch next to the set screw would loosen it, but it didn't work for me. So I put pressure on the Allen wrench while using a hammer directly on the collar close to the screw and after a few hits the screw came loose.
Slowpoke
05-25-2012 21:51:32
 Re: How do you remove a bering lock on 489 New Holland Mo... in reply to Slowpoke, 05-25-2012 21:45:07
I forgot to mention that the lock collar is a slip-on piece; the shaft is smooth, no force is necessary.
