| Restoration & Repair Tips Board |
Topic: Re: 1086 IH Digital Tach will not work
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Jon Hagen
05-22-2012 13:01:14
69.26.17.61
Use a voltmeter or test light to see if you have 12V in the plug that connects to the dig tach.Your wiring diagram may have the position and color code for the supply and ground wires. If the repair shop says the dig tach is ok, then it is a pretty good chance that it lacks power or ground on your tractor. A DVOM can test the plug for both 12V supply and ground. |
| D Rush
05-22-2012 19:18:05
24.214.247.149
Re: 1086 IH Digital Tach will not work in reply to Jon Hagen, 05-22-2012 13:01:14
| I put a new oil pressure switch on this evening and tach is working fine. Thank you very much for all the info. |
| Fixerupper
05-26-2012 04:50:14
100.42.82.164
Re: 1086 IH Digital Tach will not work in reply to D Rush, 05-22-2012 19:18:05
| I was about to mention the pressure switch but you found it. If you want to, you can put a jumper in the plug that plugs into the pressure switch to bypass the switch. Then search around and find where the power wire gets it's power and move it to a switched location instead of steady hot. That way the tach comes on whenever you turn on the ignition switch. It's been so long ago that I did that to my 1086 I've forgotten which wire it is but it's not too hard to do. If I remember right, you do it by the fuse panel. Jim |
| Jon Hagen
05-26-2012 19:25:42
69.26.17.61
Re: 1086 IH Digital Tach will not work in reply to Fixerupper, 05-26-2012 04:50:14
| Thanks guys, I did not realize that the tach was powered from an oil pressure switch on a 1066. Anyone know why that was done instead of powering it from the ignition switch ??I ran into that on later 14 series IH combines where the electro hydraulic valves were powered from an engine oil pressure switch so the reel or header drop hydraulic functions would not work if the engine was not running. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
