TractorLinks.com
Restoration & Repair Tips Board
Re: How do you remove a bering lock on 489 New Holland Mo...
Retired Farmer
05-21-2012 08:08:00
Put a punch in the hole on the outside of the lock collar and drive it off OPPOSITE the direction the shaft rotates. Doesn't need to go very far. It may be rusted on pretty good. Unless somebody drove it on in the wrong direction. Sometimes they are stuck on pretty tight. Might need lots of penetrating oil. Make sure you have the allen head set screw loose or take it out completely.
tractplow
05-21-2012 09:56:18
 Re: How do you remove a bering lock on 489 New Holland Mo... in reply to Retired Farmer, 05-21-2012 08:08:00
Thanks. I assumed it was probably opposite. Guess I need some more PB blaster.
Retired Farmer
05-21-2012 15:02:02
 Re: How do you remove a bering lock on 489 New Holland Mo... in reply to tractplow, 05-21-2012 09:56:18
Forgot to say too, you can use a little heat on the collar too, if it don't want to move. When you put the new collar on it doesn't need to be drove on real hard either, just enough to be firmly seated. If you drive it too hard you can break the edge of the bearing off. Drive it on in the direction of shaft rotation.
