Ferguson to20
BC229
New User
I am rebuilding the head and have ran into a problem with the caps on top of the valves. Does anyone know if the caps are required on new valves?. These appear to be too tall with the caps and the caps seem to be wobbly.None of the shops local know the answer.
Those da** caps always seem to fall off in use. I"ve heard that the valves can be installed without them and then adjusted to make up the length difference. I believe some folks have had a machine shop cut the valve tops down so there is a flat surface on the end. Go to the Ferguson Board and ask the question.
