Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Farmall Super A clutch won't disengage
Barstart
05-02-2012 19:29:47
Help! I rebuilt the transmission, and put everything back together the way it was, and now the clutch won"t disengage. I did put a new clutch lining in, but it was just about the same thickness as the old one, so I didn"t think adjusting it would be a big deal.
I screwed in all the arm adjusting screws, and adjusted the pedal all the way to the end of the threaded rod, and I still can"t get that drive shaft to stop moving. I"m pretty stressed about it right now (I need it this weekend) and I"m wondering if I should have adjusted something the complete other way. I"m hoping to avoid splitting the tractor. Any suggestions?
JRSutton
05-03-2012 11:55:08
 Re: Farmall Super A clutch won't disengage in reply to Barstart, 05-02-2012 19:29:47
Wish I could offer a suggestion - but nothing's popping into my head.
You'd probably be much better off posting the question in the farmall/ihc forum though. Somebody there will be able to help.
Barstart
05-02-2012 20:06:35
I've been thinking about this a little more... I had a really hard time putting the two halves of the machine back together. I wonder if I damaged the pilot bearing. Regardless, any adjustment suggestions would be appreciated before I split the machine tomorrow.
Also, what company would be a good to overnight parts to me?
old
05-03-2012 13:26:42
 Re: Farmall Super A clutch won't disengage in reply to Barstart, 05-02-2012 20:06:35
Did you maybe install the disk back wards?? If you did then it will not disengage. Also did you use a clutch aliment tool or some such thing to get the disk where is has to be?? If not and you force it back together then you stand a good chance you warp the clutch disk
dpendzic
05-08-2012 12:34:37
 Re: Farmall Super A clutch won't disengage in reply to old, 05-03-2012 13:26:42
Ok Sue--i see you got it to the show so what was the problem??
Copyright © 1997-2015 Yesterday's Tractor Co.
