Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
WD starter problems
Wilberton
05-01-2012 17:44:13
Starter on my WD would spin and grind metal every-once-in-a-while. I first thought that I had some broken teeth on fly wheel or starter gear. Took it off and can see no real damage to either the fly wheel or the starter teeth. The other starter I put on works fine. What would keep the bendix from fully engaging?
John B.
05-17-2012 19:33:49
 Re: WD starter problems in reply to Wilberton, 05-01-2012 17:44:13
Make sure the bendix gear on the starter only free wheels in one direction when turned by hand.
Wilberton
05-02-2012 20:00:58
OK, thanks. I'll look on ebay for a re-build kit.
Bob Bancroft
05-02-2012 18:05:06
It looks good from here! Does the gear spin out on the threads by hand easily? Could be brushes, fields, armature, etc. just not getting RPMs up where they should be.
soundguy
05-02-2012 12:43:12
worn bushings will make em grind and drag.
excess lube will make em drag and not engage, and thus grind upon trying to engage.. etc.
dandeere
05-02-2012 11:49:57
That starter makes the circut by grounding to the bellhousing, make sure its a good connection. It looks a little rusty, somefolks like to run a ground wire. Dan
