Yesterday's Tractor Co.
Shop Now View Cart
140 farmall stuck in reverse
04-29-2012 05:43:33
Shifter will go in other gears but when you drop the clutch tractor cuts off if you take it out of forward gear it will go backwards but shifter will not go back in reverse.
John B.
05-17-2012 19:35:59
 Re: 140 farmall stuck in reverse in reply to ChuckEglrckNC, 04-29-2012 05:43:33
Sounds like your shift lever is worn where it fits in the shift rails. This will cause it to shift into one gear and slide into another rail at the same time. This is caused by shifting too fast along with a worn shift lever.
04-30-2012 07:42:49
 Re: 140 farmall stuck in reverse in reply to watts 1, 04-29-2012 05:43:33
Sounds like it's stuck in reverse.Take the top of the transmission of, the cover with the shifter in it. Probably have to slid the reverse rail back so all the slots line up, then see what is wore out enough to let the shift slip out.
