Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Topic: jd 2010 distributor questions
[Return to Forum]
Stu MacDonald
04-24-2012 19:16:56
97.107.63.111
I have a 2010 with the prestolite distributor.
It is the original, and the bushings are work out. prestolite parts are hard to come by... can a replace it with a delco unit?
[Reply]   [No Email]
impala_stu
05-02-2012 17:14:16
97.107.63.111
 Re: jd 2010 distributor questions in reply to Stu MacDonald, 04-24-2012 19:16:56
Yeah, i can get cap, points rotor and condenser for all types, as well as springs and weights for the delco, but not for the prestolite... hence my conundrum. The springs are broken, and i would disagree with anyone who would say to use a "universal automotive spring set". Last time i checked, my 2010 doesnt hit 6200 rpm :P
I have my own machine shop, so i could redo the bushings myself, but the springs are broken, and the weights are gone. My pops said they were gone when he bought the thing. Probably whys its run like a turd for 25 years.
I can find a new prestolite of the exact same type for 175 plus shipping plus 75 core. If it lasts another 25 years, that may be the way to go. I was just looking for something i could still entirely rebuild ala delco.
Stu
[Reply]  [No Email]
impala_stu
05-01-2012 18:08:39
97.107.63.111
yup, just did that!
Thanks for the tip.
Looks like there is a presto and delco type in both tang drive and gear!
Looks like i should be able to use the delco (i think) However all 4 pn's are NLA....
Guess ill have to pull it, and got to an online retailer i found that carries rebuilt units.
Thanks guys
[Reply]  [No Email]
impala_stu
04-30-2012 17:52:26
97.107.63.111
Can anybody help me out with this one, in regards to the use of a delco distributor?
By the way, i am the original poster, but my original sign in ifo got deleted on me lol
Thanks
Stu
This post was edited by impala_stu at 17:53:42 04/30/12.
[Reply]  [No Email]
rustyfarmall
05-01-2012 05:48:21
67.55.162.174
 Re: jd 2010 distributor questions in reply to impala_stu, 04-30-2012 17:52:26
Doesn't John Deere have a website you can go to and look up the parts diagrams? You should be able to compare the two distributors and see if there are any differences in how the two are mounted, how they are driven, etc. Just off the top of my head, I can't imagine there would be any REAL differences, and I would think the Prestolite and the Delco would be readily interchangeable.
I doubt there is any real reason for your tractor to have the Prestolite instead of the Delco, except for the fact the Prestolites were what was available on the particular day your tractor was built.
[Reply]  [No Email]
impala_stu
04-28-2012 20:23:18
97.107.63.111
Earl, i really appreciate the response, but im not too keen on using another prestolite. The rebuild parts seem to be a real bugger to get a hold of.
If have have to go that route, then thats what im dealing with i guess.
What i would really like, is to use a delco. Can i replace this cruddy presto magic piece of crap with a delco?
Thanks
Stu
[Reply]  [No Email]
Earl-IL
05-02-2012 11:58:41
173.23.46.144
 Re: jd 2010 distributor questions in reply to impala_stu, 04-28-2012 20:23:18
Did you call & talk to them about parts such as points, cond,rotor, cap. Delco is no longer made, but parts ae available.
[Reply]  [No Email]
impala_stu
04-28-2012 14:11:17
97.107.63.111
It is an IBT 4101R 8M.
I havnt pulled it yet, cause i want to make sure I have one to replace it immediately. We only have this tractor, and NEED it all the time. The problem is im not sure if its gear drive, or tang.
Really the biggest problem is that its ALWAYS wet in the cap (i think there might be a bad seal) the bushings are loose, the advance springs are broken, etc etc.
Weve always had starting issues with this thing, and i want to convert it to 12v neg ground.
What i WANT to do, if i can is use a delco. Is there a delco number i can take to my automotive parts guy and get the WHOLE distributor?
My dad has been battling this thing for the 25 years weve owned it, and im finally at the point were i know enough to be dangerous, and i figure id best fix the damn thing before he burns the shop down (cause he wants to light the damn tractor up lol)
Thanks guys
Stu
[Reply]  [No Email]
Earl-IL
04-28-2012 19:59:17
173.23.46.144
 Re: jd 2010 distributor questions in reply to impala_stu, 04-28-2012 14:11:17
I sent you a email. Earl
[Reply]  [No Email]
Jo Bird
04-26-2012 15:09:11
173.87.148.245
Yes, delco units 1112577,1112623 and X-23226 will work but sub to AT361T,AT14119T and AR11145R as per my book. They also used a Wico distributor, but stay away from those, they are worse for parts than prestolite..
[Reply]  [No Email]
Earl-IL
04-25-2012 21:08:08
173.23.46.144
Would you like to buy a new Prestolite Distributor for your tractor? I think I can help you if you give me the number off the old dist.
[Reply]  [No Email]
old
04-25-2012 19:18:00
209.86.226.34
I have a JD 1010 here that is a parts tractor so I may have a distributor that will fit it. My e-mail is open and as for can you swap yes I believe you can
[Reply]  [No Email]
Jerry/MT
04-25-2012 18:25:26
206.183.116.145
You can rplace the bushing.usually the bushing and the shaft are worn so the shaft is turned and the ID of the bushing is reamed to fit. If you have an auto electric shop near you they can usually rebush them. If not, try www.the philbingroup.com. They did one for me about 5 years ago.
[Reply]  [No Email]
Earl-IL
04-24-2012 19:24:32
173.23.46.144
What is the dist number?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
