Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
Re: 2010 JD power steering
Jo Bird
04-24-2012 14:05:41
Early 2010's have a proportioning valve on the front of the case that covers the front of the transmission case. Not in the pumps. Remove the round cover on the right side of the bell housing above the foot rest. Behind the line that supplies the power steering pump oil is a three bolt cover. Behind it is the shuttle and a spring. The spring is NLA from JD. I had to make one from a stock length of spring of similar size and diam. so far has worked for 6 months.. their was a change in the design in early production. One has a round cap that sticks out and the other one is a flat triangle cover. They will not inter change, been their. PS the pump WILL come out with out splitting the tractor if you need to replace it, but with 2200 lbs pressure I doubt that its the pump. You can check the JD web site to see the diagrams. Let us know what you find.. Jo
ron rudoski
04-24-2012 19:45:19
 Re: 2010 JD power steering in reply to Jo Bird, 04-24-2012 14:05:41
Thanks Jo. Have located the plate and will check into it in the next day or two. Ron
