Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
Re: Massey 180 hydrolics
Jo Bird
04-24-2012 13:34:27
I have a 180 with similar problems.Your massey has a couple of filters. One in front of the radiator and one on the pump under the 3 point lift arms, in the rear case. The one up front is connected to the multi-power pump, mine was plugged, starving the pump of oil, replacing it made the multi-power function properly. My local massey dealer says the one in the rear case can only be reached after removing the 3 point lift arms. My 3 point arms shutter when lifting, so I will be checking it soon as I can get a service manual. Their seems to be certain bolts that hold internal piping in place which can be damaged if not removed before trying to lift the cover off. I'd hold off on replacing the pumps until after you replace the filters and oil..then test the hdy system with a pressure gauge. I'm not saying new filters will fix the problems, but their a lot cheaper than new pumps and you can not accurately test the pressure with clogged filters. Hope this helps.. let us know what you find.
