TractorLinks.com
Restoration & Repair Tips Board
2010 JD power steering
ron rudoski
04-22-2012 05:27:37
HI- lost my power steering on a 1963 2010 JD> Have 2200 lbs pressure to my remote hydraulics, but only 100 lbs to the power steering. Our first thoughts were the power steering motor in front of rad, and valving on the steering column or the mail hydraulic block under the steering column. All three check out OK so assume it is the actual hyd. pump? Am told there is a selector valve in the actual pump. Can anyone give m,e sound advice on this and if repairs are available if it is the pump. Thanks , Ron
ron rudoski
04-26-2012 08:41:55
 Re: 2010 JD power steering in reply to ron rudoski, 04-22-2012 05:27:37
Jo- we had to pull the pump out the bottom to get the three sided plate off you told us about. Pump was oK in all aspects, and spring behind the plate also OK. We pulled the spring and plunger out, and ther are two orifices in the plunger, a large one and smaller one. The smaller one had about an inch long piece of silicone driven into it and caught on both sides in the spring. Also a couple more small pieces of silicone in where we removed the parts. Everything else looks good, and definitely the silicone is foreign, and will advise when we get it back together. Have to order some O rings so will be about a week before we know for sure.
If you want to contact me personally,I posted my email address, but will also post results on this forum for anyone else watching.
Again thank you, and as matter of interest, the service manager at the local JD dealership didnt know that the part you told me about even existed. I realize these are old tractors, and were built before the fellow was born. ( in his defense)
Ron
Jo Bird
04-25-2012 16:13:19
Ron
Your welcome, I don't know where my mind was, the plate only has 2 bolts not 3. I replaced the bolts with some all thread about 2" long to make it easier to get the assembly back in, there isn't a lot of room to work in..
ron rudoski
05-04-2012 05:50:25
 Re: 2010 JD power steering in reply to Jo Bird, 04-25-2012 16:13:19
Problem solved thanks to you Jo Bird. As mentioned, the small piston behind that plate had a piece of silicone forced through it by the hydraulic pressure, plugging the orifice. Cleaned it, checked for more silicone, and did find a couple tiny pieces (dont know how it got past the filter) and "presto" power steering restored. Would suggest if you have hydraulic pressure , this is the place to look first. Could of saved about 8 hours of labor if I had used this site first. Thanks again to all responses, and especially the solution from Jo.
Jo Bird
04-24-2012 14:05:41
Early 2010's have a proportioning valve on the front of the case that covers the front of the transmission case. Not in the pumps. Remove the round cover on the right side of the bell housing above the foot rest. Behind the line that supplies the power steering pump oil is a three bolt cover. Behind it is the shuttle and a spring. The spring is NLA from JD. I had to make one from a stock length of spring of similar size and diam. so far has worked for 6 months.. their was a change in the design in early production. One has a round cap that sticks out and the other one is a flat triangle cover. They will not inter change, been their. PS the pump WILL come out with out splitting the tractor if you need to replace it, but with 2200 lbs pressure I doubt that its the pump. You can check the JD web site to see the diagrams. Let us know what you find.. Jo
ron rudoski
04-24-2012 19:45:19
 Re: 2010 JD power steering in reply to Jo Bird, 04-24-2012 14:05:41
Thanks Jo. Have located the plate and will check into it in the next day or two. Ron
northvale-PA
04-23-2012 15:33:43
I have a 2010 gas with the same problem, 3 years now. I assume a spring broke inside the pump as the 3pt hitch works, but that was always alittle weak. The hose outlets were weak too, so I assume it was a weak spring that eventually broke. Be nice to hear what your fix is.
ron rudoski
04-22-2012 10:44:17
Thanks, mines a gas model, and no problems til this for the past 28 years. Have moved countless numbers of 12-1400 lb bales with it.
buickanddeere
04-22-2012 09:43:39
First hand experience with 2010 PS is limited as PS was still sort of a novelty option back then. Also most 2010's, in particular diesels have been scraped. There is likely some info in the factory service manual at 1-800-522-7448. Here is a link to the JD web page parts section where a look at the PS internals and part #'s can be had. The PS unit and hydraulic pump appear to have been used only on the 2010. Some equipment does share common pumps and PS with several tractors, combines, forage harvesters, industrial equipment etc.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
