1939 9N starter problems
Anonymous-0
I have a '39 Ford 9N. It's been running fine until last week when I went to start it. I could here that the starter was making noise, but it was not turning the motor. It just made a whinding noise. I am not a mechanic by any means, but I pulled the started off hoping to find a gear with the teeth ground down or something simple I could fix. When I got it off, the gears looked fine. The wierd thing is that the tractor sat all through winter (I live in Ohio)and started right up the first time I started it this spring. Two weeks later when I went to start it is when this happened. Does anyone have any thoughts/suggestions?
Thanks,
Derrick
More than likely the spring on the starter drive (that gear you mention). That or some rust or crud on the shaft keeping it from throwing in. You can hook jumper cables to it to test it. Just hook one cable to the stater case and touch the other one to the post. The gear should come ahead when it starts up.
I'm having trouble removing the pin from the shaft to pull off the drive see if the spring inside is broken. My tractor has been converted to 12 volt and my starter does not match the one in the manual I have. Do you know if there is a trick to remove the pin? I was hitting it pretty hard and made no progress...
Thanks
a lil washer sets over the pin.. you have to hold the washer down.
in any case.. if the starter spins but drive doesn't suck in, make sur ethe shaft is clean.. spray cleaner like carb spray the shaft and drive.
next buff the mating place the starter hits the bellhousing.. then make sure all yer cables and connections are good.
NO LUBE on the shaft or drive.. lube creates drag.. drag makes for slower speed.. slow speed makes it not travel and engage..
post back
I got it off and a new one on. Put it back on the tractor and it started right up. Thanks for the help!
