| Restoration & Repair Tips Board |
Topic: 1939 9N starter problems
[Return to Forum]
| Author |
[Modern View]
| Derrick Palmer
04-15-2012 12:17:39
76.5.123.180
I have a '39 Ford 9N. It's been running fine until last week when I went to start it. I could here that the starter was making noise, but it was not turning the motor. It just made a whinding noise. I am not a mechanic by any means, but I pulled the started off hoping to find a gear with the teeth ground down or something simple I could fix. When I got it off, the gears looked fine. The wierd thing is that the tractor sat all through winter (I live in Ohio)and started right up the first time I started it this spring. Two weeks later when I went to start it is when this happened. Does anyone have any thoughts/suggestions? Thanks, Derrick |
| rrlund
04-15-2012 12:55:04
207.241.137.116
Re: 1939 9N starter problems in reply to Derrick Palmer, 04-15-2012 12:17:39
| More than likely the spring on the starter drive (that gear you mention). That or some rust or crud on the shaft keeping it from throwing in. You can hook jumper cables to it to test it. Just hook one cable to the stater case and touch the other one to the post. The gear should come ahead when it starts up. |
| Derrick Palmer
04-16-2012 15:51:55
24.31.185.176
Re: 1939 9N starter problems in reply to rrlund, 04-15-2012 12:55:04
| I'm having trouble removing the pin from the shaft to pull off the drive see if the spring inside is broken. My tractor has been converted to 12 volt and my starter does not match the one in the manual I have. Do you know if there is a trick to remove the pin? I was hitting it pretty hard and made no progress... Thanks |
| Derrick Palmer
04-17-2012 04:18:31
98.102.158.196
Re: 1939 9N starter problems in reply to Derrick Palmer, 04-16-2012 15:51:55
| I did some more digging... My starter is not different, just the drive bendix... Thanks, Derrick |
| soundguy
04-19-2012 10:17:15
107.41.110.205
Re: 1939 9N starter problems in reply to Derrick Palmer, 04-17-2012 04:18:31
| | a lil washer sets over the pin.. you have to hold the washer down. in any case.. if the starter spins but drive doesn't suck in, make sur ethe shaft is clean.. spray cleaner like carb spray the shaft and drive. next buff the mating place the starter hits the bellhousing.. then make sure all yer cables and connections are good. NO LUBE on the shaft or drive.. lube creates drag.. drag makes for slower speed.. slow speed makes it not travel and engage.. post back |
| Derrick Palmer
05-01-2012 09:13:35
98.102.158.196
Re: 1939 9N starter problems in reply to soundguy, 04-19-2012 10:17:15
| I got it off and a new one on. Put it back on the tractor and it started right up. Thanks for the help! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
