TractorLinks.com
Restoration & Repair Tips Board
Re: case vac cam
El Toro
04-15-2012 11:03:33
Put a wanted ad in "Classified Ads" under Marketplace in the upper left on your monitor's screen. You should be able to find one from there. Place your request over on the Case forum. Hal
actionpack
04-15-2012 17:51:26
 Re: case vac cam in reply to El Toro, 04-15-2012 11:03:33
thanks , would'nt know off hand what would cause the first gear to break would ya ,
old
04-15-2012 17:57:43
 Re: case vac cam in reply to actionpack, 04-15-2012 17:51:26
I have a VAC parts tractor and I think I have a couple cams on hand. E-mail is open
actionpack
04-15-2012 18:08:43
 Re: case vac cam in reply to old, 04-15-2012 17:57:43
sounds good , let me check a local junk yard tomarrow that mite have a vac they took in for salvage , if that don't work i will be emailing you about the cam , the junk yard mite part with the whole tractor cheap if i'm lucky , thanks , and i'll let you know
actionpack
04-16-2012 15:53:52
 Re: case vac cam in reply to actionpack, 04-15-2012 18:08:43
i sent a email old ,
actionpack
04-18-2012 13:28:53
 Re: case vac cam in reply to actionpack, 04-16-2012 15:53:52
the tractors i looked at had the hydro pump in the front of the engine , but they did'nt run off the fan belt , they were installed on the front timming cover , is this what you have , or is it like you said , they run from a belt
