TractorLinks.com
Restoration & Repair Tips Board
sleeve removal
rich o
04-14-2012 15:51:19
any tips or tricks on removing cylinder sleeves without any 'specialty' tools
buickanddeere
04-30-2012 06:11:31
 Re: sleeve removal in reply to rich o, 04-14-2012 15:51:19
1st and foremost sleeve removal does not involve the use of a hammer/sledge.
showcrop
04-30-2012 05:04:14
I made my own puller out of scrap and a piece of one inch threaded rod. You don't need a precise fit of the disc until you have broken it loose. I used a very heavy piece for breaking them loose, then put in a piece that I cut and ground into nearly a circle to bring it the rest of the way out.
Nebraska Kirk
04-29-2012 19:45:35
You really should have or use a special dedicated tool to pull the sleeves. You could try the welding trick, but unless you are a good welder and have confidence in your abilities, you risk burning through the sleeve and damaging the engine block.
El Toro
04-15-2012 11:15:23
You need a puller like Keith made for his SuperC.
Hal
Welding man
04-14-2012 16:26:45
Wet or dry sleeves? What Engine? More info needed.
rich o
04-14-2012 17:25:18
 Re: sleeve removal in reply to Welding man, 04-14-2012 16:26:45
dry sleeves, perkins deisel ad4 203
J. Schwiebert
04-15-2012 17:32:21
 Re: sleeve removal in reply to rich o, 04-14-2012 17:25:18
If they are like a 354 Perkins you are going to need a 20 ton hydraulic puller
Welding man
04-14-2012 19:40:28
Some people run a couple of beads of weld down the sleeve-let it cool and they will come out. you have to be very careful not to burn through. personally I press them out in a hydraulic press with a plate machined like a bushing driver.you can use this same plate, a piece of 6 in pipe and a piece of all thread rod to pull them out. Not rocket science-just a few simple homemade tools, but I do own a machine shop.I put a new set in a Farmall 300 yesterday. Took about an hour.
