blackdiamond
New User
hope this is the right place to post. i have a john deere 510 3 cylinder diesel tractor that purred like a kitten and then just shut off. there is fuel to the injector pump but no fuel to nozzles. i removed timing cover on pump to line up marks (roosa master) but no matter how much i turn it , i don"t see the second mark (governor mark i think) to line up. i looks as if the forward part is not turning. i believe it is suppose to turn. any tips would be helpful. i want to pull the pump off , but i would like to line the marks up first. also is there a sure way to determine if i am at TDC (compression stroke)using the flywheel pin besides pulling the valve cover and looking at the valve position? thanks in advance.
bruce
bruce
