Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Topic: Farmall Super A will not restart when hot.
[Return to Forum]
Jeff32j
04-08-2012 17:00:36
67.54.222.134
My Farmall Super A (6 volt, + ground)will not start after I"ve used it for a while and the engine is hot. Is this a bad coil on the magneto or something else?
[Reply]   [No Email]
Jeff32j
04-11-2012 15:51:52
67.54.193.223
Re: Farmall Super A will not restart when hot. in reply to Jeff32j, 04-08-2012 17:00:36
Thank you all for the help. I plan to work on it this weekend.
I'll let you know how it goes!
  [Reply]  [No Email]
JRSutton
04-10-2012 17:13:07
75.130.109.233
My first guess would be the coil - when they fail, they often stop working when hot - and, often get hot when they stop working.
Feel the coil - if it's suprisingly hot, that'd be enough to suggest a new one.
  [Reply]  [No Email]
El Toro
04-09-2012 04:04:34
108.3.225.57
When the engine quits running pull off a plug wire asap and check for fire to your plug. If there's no fire replace the condenser. If that doesen't fix the problem you probably need a new coil.
If you have fire you probably have a fuel problem. Check the flow from the tank to the carburetor. Should see a full stream of gas and if that looks ok pull the tube fitting where your gas line connects and look for a screen that may be plugged. If that screen isn't plugged clean your carburetor by soaking in carb cleaner and blowing out the jets using air pressure. Hal
  [Reply]  [No Email]
JMS/.MN
04-08-2012 22:18:11
209.237.107.155
Growing up, we had a couple AC tractors do that- they would start instantly if pull started. Magneto rebuilds cured both. Just another option.
  [Reply]  [No Email]
John B.
05-17-2012 19:44:00
38.114.64.135
Re: Farmall Super A will not restart when hot. in reply to JMS/.MN, 04-08-2012 22:18:11
I agree with JMS. We had a farmall "A" hand crank for years. Had a belly mower on it. IF you killed it mowing it had to be pull started cause cranking it by hand wouldn't make it start. Pull it ten feet it popped right off. It was a weak coil. The coils always have the date on them. The one we replaced in it was dated 1939. We replaced it in the 1980's.
  [Reply]  [No Email]
Kip-Utah
04-08-2012 19:43:59
75.169.70.104
Check valve adjustment. If thet are on the tight side the valves will get too tight when hot.
  [Reply]  [No Email]
DeanOlson
04-08-2012 17:48:24
98.196.66.64
Some diagnostics: Check fire, fuel and air.
I carry an extra spark plug in my tool box so I can check for fire when tractor fails to start. My super C started running rough and then quit. It wouldn't restart. No fire and coil was too hot to touch. I swapped coil out and problem resolved.
Another time it developed and intermittent starting issue whether it was hot or cold. That ended up being the condenser.
Check for fuel flow by unscrewing the drain plug on the carb. Probably not an issue in your case.
Check the air cleaner. Back in the day, when I had no building to park a tractor in, rain would collect in the air cleaner oil bath cup and cause a flooding problem. It would start fine but after it warmed up it would run rich and not want to restart easily when warm.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
