TractorLinks.com
Restoration & Repair Tips Board
crankshaft pulley removal
rich o
04-06-2012 19:04:50
any tips on removing the crankshaft pulley from my massey 65, when i try to break the nut , the crank turns as well, were would i stabilize the shaft to remove the nut?
El Toro
04-08-2012 06:22:00
 Re: crankshaft pulley removal in reply to rich o, 04-06-2012 19:04:50
Use a piece of oak to jam the crankshaft from turning. Then use an air impact to loosen the nut. Hal
JOHNNYfromMI
04-08-2012 12:01:05
 Re: crankshaft pulley removal in reply to El Toro, 04-08-2012 06:22:00
Some have left hand threads!
showcrop
04-07-2012 10:14:34
I have put a long wrench on it and then hit the other end of the wrench with a hammer.
Jerry/MT
04-07-2012 10:08:17
Put the tractor in gear and then use a puller on the pulley after you remove the nut.
El Toro
04-07-2012 08:34:49
Use a 6 point socket and an air impact wrench that's been mentioned. Use a 3/4 impact if you have one. Hal
PS: Make sure you're turning it CCW to loosen.
greygoat
04-07-2012 08:12:06
Any time I've tried to take that nut off, I've
put the transmission into gear!
JMS/.MN
04-06-2012 20:41:47
Is there room to get in with an impact wrench?
rich o
04-07-2012 04:24:05
 Re: crankshaft pulley removal in reply to JMS/.MN, 04-06-2012 20:41:47
yes block is nearly stripped down, just when i try to remove bolt ,the crankshaft spins as well, were would i 'wedge' something to stop rotation of shaft. i see some small bore holes in the fly wheel that could possibly do the trick but i wanted to know how the experts do it
MFJohn
04-09-2012 04:20:08
 Re: crankshaft pulley removal in reply to rich o, 04-07-2012 04:24:05
If you"ve pulled the oil pan, jam a 2 by 4 between the crankshaft and the block so it can"t turn.
