TractorLinks.com
Restoration & Repair Tips Board
Re: IH utility 300 motor stuck??
El Toro
04-01-2012 08:30:13
You should pull the engine and have the crankshaft measured for wear. Would be a good time have new cam bearings installed. They won't grind the crankshaft undersize unless it needs it. If it's worn slightly and needs .002" undersize bearings they will just polish the shaft. Buy your new bearings from them. Hal
Stevewatr
04-01-2012 18:06:56
 Re: IH utility 300 motor stuck?? in reply to El Toro, 04-01-2012 08:30:13
Well Hal, pulled the pan today, removed the rod cap for cylinder #2, and the journal is scored! So now I am looking at pullling the crank, meaning pulling the block, so I'm on my way to a full rebuild of this motor, on a tractor that I know has a steering gear issue, and I've never seen run..........I think I need my head examined!
El Toro
04-02-2012 12:29:56
 Re: IH utility 300 motor stuck?? in reply to Stevewatr, 04-01-2012 18:06:56
Sometimes it's better to let them go for scrap.
When you need tires and a complete engine rebuild
I would think twice before buying one stuck. I did alright in 1975 when I bought a Farmall A that was stuck. I gave $100.00 for the tractor and moldboard plow. It needed tires, rims, steering wheel, seat, wiring and a complete engine rebuild. Hal
Stevewatr
04-02-2012 12:48:05
 Re: IH utility 300 motor stuck?? in reply to El Toro, 04-02-2012 12:29:56
You may be right about that, but I own it now, and am finding some very reasonable prices on the engine parts (so far). I already have new valve guides, and intake valves ordered, and I? can get a set of 4 sleeve assemblies with new pistons/rings and not get beaten up too bad. I gave $400 for the tractor, with a loader, a drawbar to fit the fast hitch, 2 arms that slide in the fast hitch to convert to arms like on a 3 point. Also came with a pretty new looking top link, and extra loader valve, and an unidentified box scraper. The upper arms on the box are bent, but I might be able to straighten them in my shop press.
