Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
Re: 8N Hydraulic lift
Pete Gray
03-27-2012 08:30:16
Thanks for the information. I am going to my farm today and will measure. I got this tractor recently and the height has not changed. Thanks Pete
03-27-2012 10:24:07
 Re: 8N Hydraulic lift in reply to Pete Gray, 03-27-2012 08:30:16
one thing you can check, once it's lifted, len on the draft lever a bit and see if ti comes up more.. also may try to adjust the quadrant.. otherwise if not lifting as high as it should, it's likely a worn cam follower pin and / or cam.
Pete Gray
03-27-2012 13:14:26
 Re: 8N Hydraulic lift in reply to soundguy, 03-27-2012 10:24:07
Thanks for the help. The lift will come up approximately 24"-25" from the ground to center line of bushing. I will try the draft lever and see what happens. Thanks Pete
03-27-2012 13:59:13
 Re: 8N Hydraulic lift in reply to Pete Gray, 03-27-2012 13:14:26
if it's coming up 25" it's pretty much there. the last 3/4" is probably a lil wear on the follower pin. might take that up with a quad adjustment.. otherwise it's almos tnot worn enough to mess with.. yer only gonna gain 3/4 of an inch!
