TractorLinks.com
Restoration & Repair Tips Board
Re: long time, no run 856
gleanerguy
03-23-2012 13:15:41
If its in the shed, you shouldn't have any serious problems. Check the engine oil and trans-hydraulic fluid of course. I'd drain the fuel tank and fuel lines and replace the fuel filter. Put in new fresh fuel and bleed it out.
I can't think of anything that you would ruin if its been inside out of the weather, other than you might have some seals that dried out and will now leak. You'll find that out soon enough when you start it up and run it for awhile. Sometimes tires will dry rot if they sit around long enough.
CPACy
03-26-2012 07:50:16
 Re: long time, no run 856 in reply to gleanerguy, 03-23-2012 13:15:41
I'm tempted to just pull the plug and filters on the oil and start fresh. Last time I looked there wasn't any water or anything in the oil, but I'm not sure the last time it was changed before it went in the shed, so it's probably due anyway.
