1951 Farmall H Throttle Assembly
Glen C.
New User
Is it possible to replace the saw-tooth style throttle assembly with the friction lever style? Looking for an easy fix to assembly with worn out saw-tooth assembly.
Glen I have taken a three corner file and recut the saw teeth. You might have to put a thin washer behind spring to give it a little tension after cutting them deeper.
(quoted from post at 21:06:14 03/23/12) Is it possible to replace the saw-tooth style throttle assembly with the friction lever style? Looking for an easy fix to assembly with worn out saw-tooth assembly.
YES! The M&W friction style is DESIGNED to be a replacement for the original saw tooth style.
Thanks MisterT and others who posted replies. Do you have a parts source for the "M&W Friction Assembly" you reference? Does YTMAG sell?
