| Restoration & Repair Tips Board |
Topic: long time, no run 856
[Return to Forum]
| Author |
[Modern View]
| CPACy
03-23-2012 11:59:13
4.53.5.130
Have a IH 856 in my Dad's shed that I'd like to restore and bring back to life. It hasn't been run/started in about 4-5 years but went into the shed in running condition. What should I do first so I don't damage anything? I know the batteries are shot, but I don't want to damage the engine. I'm new, so this might be an easy one, but I don't know. Any tips? |
| Dieseltech
03-24-2012 17:55:39
199.16.223.2
Re: long time, no run 856 in reply to CPACy, 03-23-2012 11:59:13
| Loosten all 6 lines at injectors, open throttle as if starting and see if fuel is delivered at all injectors, if so it should start after all are tight. If no fuel may have valves and plungers stuck from stale fuel, will need cleaned and resealed to get working again. Just resealed a JD 4020 that had sat for 1 year, valves and plungers were stuck, looked like old wesson oil inside but worked fine after resealing. If pump does need to come off drive adapter should be removed and resealed also as drive seals are not in pump tube but in adapter assy. Old seals may be hard and cracked over time. IH also had 2 style banjo lines, some had a step on each side, used 2 18829 nylon washers on each line. Plain flat banjoes could use 2 copper or steel washers, or nylon washers with a steel washer to limit crush of seal. Make sure same is on each side of line or bolt will bottom in hole, head will seize, and shaft will break. Have seen it happen too many times in years past. |
| CPACy
03-26-2012 07:48:42
4.53.5.130
Re: long time, no run 856 in reply to Dieseltech, 03-24-2012 17:55:39
| thanks for the heads up on this. |
| gleanerguy
03-23-2012 13:18:40
199.150.177.32
| Another thing I forgot - check the belts and hoses for any big cracks - they might have dry rotted from sitting. |
| gleanerguy
03-23-2012 13:15:41
199.150.177.32
| | If its in the shed, you shouldn't have any serious problems. Check the engine oil and trans-hydraulic fluid of course. I'd drain the fuel tank and fuel lines and replace the fuel filter. Put in new fresh fuel and bleed it out. I can't think of anything that you would ruin if its been inside out of the weather, other than you might have some seals that dried out and will now leak. You'll find that out soon enough when you start it up and run it for awhile. Sometimes tires will dry rot if they sit around long enough. |
| CPACy
03-26-2012 07:50:16
4.53.5.130
Re: long time, no run 856 in reply to gleanerguy, 03-23-2012 13:15:41
| I'm tempted to just pull the plug and filters on the oil and start fresh. Last time I looked there wasn't any water or anything in the oil, but I'm not sure the last time it was changed before it went in the shed, so it's probably due anyway. |
| old
03-23-2012 12:46:07
209.86.226.18
| Gas or diesel??? Make a difference as to where and what to do. |
| CPACy
03-23-2012 12:50:05
4.53.5.130
Re: long time, no run 856 in reply to old, 03-23-2012 12:46:07
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
