Anonymous-0
hello all, i am new here. i am 28 and just bought my first old tractor to restore a 50 john deere late model b . problem is when i shut the tractor off, the ammeter shows i am drawing current. some one in the past took the wires off the voltage regulator. the regulator is a 3 terminal. can anyone tell me what wires are supposed to be connected where, or if this regulator will work. it has a field, generator, and battery terminal. i have read a couple places you need a special light switch for it to work. mine just has a plain toggle switch. they had the field wire on the generator grounded. also the starter turns over very slow, too slow to start the tractor even with a brand new, fully charged battery. (i disconnected the generator to keep if from draining the battery) what might be wrong with the starter. thank you very much for the help........... carl
