TractorLinks.com
Restoration & Repair Tips Board
Re: Farmall Super A clutch won't disengage
glennster
03-20-2012 14:08:06
i have an h that the clutch will stick over winter if i dont block the pedal down. if you have an open area you can start the tractor in 3rd gear and drive it around with the clutch depressed, hitting the brakes several times. this may pop it loose. hooking an implement like a plow will put a load on it too, if you can access the clutch disc thru the starter hole or lower inspection hole, you may be able to reach up with a screwdriver and pop the disc loose. i did that on an international 254.
