Topic: 4020 load control shaft help
[Return to Forum]
| Author |
[Modern View]
| rmonte888
01-22-2012 07:23:24
70.117.248.9
I have a newer model 4020 thats leaking from the shaft.
I replaced the shaft and the seals. Oil ring type.
Its still leaking. Im thinking of replacing the bushing thats inside but the JD dealer does not carry it. They told me that I would have to buy the bushing which is around $150 for both and then take it to the machine shop and have them cut like my old ones. I will post a pic when I remove them. All the ones I've seen on the internet dont look the same as the one I have.
Why would they still leak?
New shaft and seals?
Monte
This post was edited by rmonte888 at 07:27:59 01/22/12. |
[Reply] [No Email] | |
| hazmt
05-27-2012 11:43:50
4.79.200.34
Re: 4020 load control shaft help in reply to Bob, 01-22-2012 07:23:24
| When you replaced the load shaft seals did you install them with the flat (wide) side out or in? I have worked on a JD 4020 load shaft leak about 4 times over the past three years! Turns out the seals were installed backwards originally. Also another common problem is that folks use a screwdriver to pry out the old seals - scratching up the transmission housing in the process (according to the shop manager at the local JD dealer). When this happens the trans oil will leak out around the seal. Clean the transmission housing, use high temp silicon in a thin layer where the seal seats and then install new seals correctly (sharp edge out). This should fix the leak. I had multiple issues originally (backward seals, worn load shaft and scratched seal housing). I replaced the shaft, did the silicon trick and installed new seals correctly and finally got the leaks stopped. Hope your problem gets solved more quickly than mine did. Best regards! |
| rmonte888
01-23-2012 19:00:32
70.117.248.9
Re: 4020 load control shaft help in reply to challenger, 01-22-2012 07:23:24
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
