| Restoration & Repair Tips Board |
Topic: Carter UT problem
[Return to Forum]
| Author |
[Modern View]
| Tony Loretelli
01-10-2012 14:10:49
65.170.221.57
While in the process of trying to rebuild a Carter 2612 aluminum body carb off a 1957? Z-134 MF 50, one of the float pin supports got broken off. I'm thinking of trying J-B weld or aluminum solder to repair. Can anyone see any harm in trying? Any thoughts on fixing the float pin in place without one support? And finally, if none of the above works, suggestions on where to find a replacement carb or an upgrade that would fit? Thanks for any replies. |
| rexbeavers
01-13-2012 12:21:11
72.28.19.245
Re: Carter UT problem in reply to Tony Loretelli, 01-10-2012 14:10:49
| put ad in clasified that you are thying to find a carb give model # an what it"s off of an your location theres guy that have alot of parts for tractors |
| ShadetreeRet
01-11-2012 21:22:57
184.2.210.187
| I don't think the float would function properly with only one pin support. Chances are it would bind and cause problems. I think I would try t locate another carb. |
| Bob M
01-11-2012 14:38:14
67.240.168.45
| | JB Welding the support back on will hold it for a while. However when exposed constantly to gasoline, JB Weld will eventually soften and let go - even when fully cured. Better to take the casting to a good welder and have him heliarc the tab back on. Or go for a replacement carb. |
| rustyfarmall
01-11-2012 05:50:37
216.248.71.224
Re: Carter UT problem in reply to Bob, 01-10-2012 14:10:49
| Quoting Removed, click Modern View to see
JB Weld might work, but make sure it is completely cured before introducing it to gasoline. Even then, I wouldn't spend much time on it. A Zenith or a Marvel-Schebler carburetor, either new or used is the way to fix it. |
| VACLee
01-10-2012 19:20:20
184.35.100.194
| That carburetor was also used on the Oliver Super 55, 66 and Super 66 although I don't think there were a lot of them produced with it. It was also available in a cast iron version on those plus Farmall Super A, C, Super C, 200 and 230. Again I don't think it was as popular as some other make carburetors were. Lee |
| J.Wondergem
01-10-2012 16:09:59
166.249.103.93
I believe, if it were me, I'd try soldering it, if it's brass. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
