1903bluepill
I"m restoring a 1918 Cleveland Tractor mod H
crawler engine and want to reduce my .030
crankshaft end play to .002. Since NOS bearings
are non existent my thoughts are to build up the
forward shell flange of the front bearing as it is
the most worn. The wear is coming from contact
with the rear of the gear on the nose of the
crank.
I plan to turn down an existing bronze thrust
washer to the correct dimensions, cut it in half,
pin the halves(brass pins)on the flange faces, and
then ever so gingerly spot weld them at the edges
for added strength-of course being careful not to
heat the shell up and melt the babbitt.
Any of you folks ever done this before? Is there
any easier fix? What are your thoughts?
crank.
