I have had a Farmall 200 for about 15 years and it has always ben dependable. A couple months ago it would occasionally just quit. It would typically start again right away, but somtimes i would have to pull it in the winter because the battery has never cranked it very well even when fully charged. It sure seemed like a switch problem because it would just cut out like you turned it off. I replaced the switch but it did not help.
Anyway I lived with the occasional stall for a couple months figuring if it got worse I would have to look at it. Well it got worse. It will not start, or even fire. I suspected a ground issue so I replaced the battery cables with bigger ones. I also replaced the old cracked an brittle ignition wires. I tested voltage at the coil and it is good. The points were a little worn so I replaced them along with the condenser, the rotor and the cap while I was at it. Also the plugs. All these things while probably not totally necessary, were probably due anyway.
I have spark at the plugs and the timing seems right ( I have repeatedly checked with multiple helpers...)
It will not fire at all even with starting fluid. I thought maybe I messed up the wires on the distributer cap, but have checked it repeatedly and they seem right.
I checked compresssion and it is about 90 in all 4 cyl.
I still think it is something with a ground issue or weak spark ( i tried a new coil too) but I am at a loss for what else to try. Any ideas would be a big help.
Thanks
Thanks
