lblock
Anyone know if I can modify my gas carb to work on Lp?It is becoming quite a chore to locate a Lp carb for my super m.
Thanks
Larry O
(quoted from post at 04:56:21 10/11/11) Anyone know if I can modify my gas carb to work on Lp?It is becoming quite a chore to locate a Lp carb for my super m.
Thanks
Larry O
Sure you can modify a gasoline carb to run propane. You will ruin it for running on gasoline.Simply drill out the main jet and install a tube running into the venturi. install a regulator and away you go. You could also use an addon venturi in the intake hose. Not the same as a lp carb but will work
