| Restoration & Repair Tips Board |
Topic: Solder slinging and all
[Return to Forum]
| Author |
[Modern View]
| GenQuest
10-04-2011 07:35:43
141.0.8.40
Old Allis cut out post: ytforums.ytmag.com /viewtopic.php?t=807835 Am I right in reading this that if I use a diode for cut out, that I am safe from ruining my generator by "solder slinging" and all and that those persistant stories are pure unadulterated bull cr@p? |
[Reply] [No Email] | |
| JMOR
10-05-2011 18:43:05
72.181.167.250
Re: Solder slinging and all in reply to JMS/.MN, 10-04-2011 07:35:43
| Quoting Removed, click Modern View to seeB.S. It is NOT a problem. I guess you measured the voltage drop across the loose battery terminal and found it to be 0.7 volts? Or maybe 8 or 9 milli-ohms? By the way what happened to the 10 ohm forward resistance you quoted for the diode? At 11amps plus the junction, that would be 0.7 + (11 X 10) = 110.7 volts.
Now that might stress the generator! But we know that your 10 ohms is total fiction. |
| 36 coupe
10-13-2011 04:27:59
72.55.252.209
Re: Solder slinging and all in reply to JMOR, 10-05-2011 18:43:05
| Go measure the forward resistance of any diode.Many diode packages are marked .7 volt drop.You dont know much about diodes, they generate a lot of heat because of the voltage drop. |
| 36 coupe
10-05-2011 16:35:44
72.55.252.209
Re: Solder slinging and all in reply to GenQuest, 10-04-2011 07:35:43
| I have a Ford generator you can look at.It does have solder melted and burnt armature wires from running with a loose battery cable.A diode has a .7 volt drop across it.7.3 and .7 adds up to 8 volts.This is the danger point for old 11 amp generators.The armatures are wound with a #17 wire.Ford recommened no more than a .2 volt drop across a cut out so you want to use a diode that has 4x that amount. |
| JMOR
10-05-2011 07:10:15
72.181.167.250
Re: Solder slinging and all in reply to BeerGeek, 10-04-2011 07:35:43
| Quoting Removed, click Modern View to see 3rd BRUSH. No cut out has regulation, as I'm sure you are aware. This question always comes up for 9N/2N generator/cut out installations and the same regulation that worked for the cut out still works for the diode, i.e., the HI/LO adjuster moving the 3rd brush.........3rd brush adjust on Allis Wd, of the original post, does same job.
OK, now my question: what is a "tickle switch" as far as "regulation" is concerned? How does it work to regulate? |
| soundguy
10-13-2011 06:07:16
184.245.122.3
Re: Solder slinging and all in reply to JMOR, 10-05-2011 07:10:15
| | tickle switch would be 'emanual' regulation. IE, a high / low charge knob on the dash, with a higher and lower value resistor for biasing the field. also.. some tractors had lamp switches that also either jumped in a smaller value resistor in line with the field, vs a large static one, or jumped the ressistor out completely, to get higher charge when lamps are on... my allis G has this setup.. a circuit genny, cutout, and 1 resistor that gets bypassed when lamps on. crude.. but just like the 3rd brush / adjuster jobs.. works, only using a 2 brush a circuit genny and various resistors and switches. soundguy |
| soundguy
10-05-2011 05:34:01
173.104.28.183
| | the diode just replaces the cutout. it doesn't do ANYthing vs regulation. whatever method of regulation it has still needs to be in place.. IE.. tickle switches and whatnot.. etc. soundguy |
| 36 coupe
10-13-2011 05:43:09
72.55.252.209
Re: Solder slinging and all in reply to soundguy, 10-05-2011 05:34:01
| I had a 38 Ford that had a rheostat on the dash that let you adjust the charge rate from the drivers seat.It had a South Wind gas heater.The glo plug drew a lot of current to light to lite the gas and shut off when the combustion got hot enough.You could turn the generator to full out put at night and turn it down in day time.This would work fine on Ford tractors with a 3 brush generators.The rheostat was 3 ohms 25 watt. |
| soundguy
10-13-2011 06:00:57
184.245.122.3
Re: Solder slinging and all in reply to 36 coupe, 10-13-2011 05:43:09
| | I actually like the 3 brush jobs.. not hard to convert to using a regulator either... if you wanted to.. etc.. soundguy |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
