farmall 350 diesel block compatability with super H
I have several questions. Will a 350 diesel block bolt on to a super H? Will the front cover from a super H bolt on to a 350D block? Can the 350D crankshaft be run in the super H block? Will a super H cylinder head bolt on to a 350D block?
(quoted from post at 21:55:48 09/18/11) I have several questions. Will a 350 diesel block bolt on to a super H? Will the front cover from a super H bolt on to a 350D block? Can the 350D crankshaft be run in the super H block? Will a super H cylinder head bolt on to a 350D block?
I am fairly certain that a 350 diesel engine block will fit in a super H, however, a Super H front cover will not fit a 350D block. A 350D crankshaft will not fit in a Super H block, nor can a Super H head be mounted on a 350D block.
The 350 diesel engine is totally different from the gasoline engine used in the Super H, while the entire engine from one can be made to fit the other tractor, individual parts from the one engine will not fit the other.
If I'm not mistaken, the Farmall 350 diesel engine is a Continental engine. It was not built by IH, so it's very unlikely any of the parts would interchange, although I think it to be very likely that entire engine assemblies WOULD interchange.
