Byron F. Stone
My 3 point lift arms will not move since I changed the fluid,filter etc. I did this in stages...I drained all the old hyrdaulic oil,repaces the filter ( which was not even working as all the parts were loose in the canister)this I did about six months ago.
I installed a new carb & got it running & was going to hook up the bushog & try under load. I then remembered I only put 6 gallons of oil in ....so I added the gallon #7...checked the fluid level plug ...no fluid in sight. I added another 5 gallons ...1 gallon at a time checking the level plug each time ....never did get fluid out of the level plug.
Questions...where all the extra fluid gone & why will my lift arms not work?
