2020 remote hydro question ....
drunes
New User
I have one remote on my current 2020 and I am looking to add another for implements as the curent remote is used for the loader. Any suggestions on where I can find information and parts on adding one?
Easy to repair the error in the current loader
connection when somebody made a mistake and used
the scv.
Loaders, log splitters, hydraulic motors and
other high demand hydraulic loads on scv's. They
don't work worth a darn on Dubuque and Mannheim
tractors.
Install a "T" in the high pressure line running
prior to the rockshaft and scv valve. To supply
the loader.
Return the loader oil to a ported transmission
oil filter cover.
The transmission oil pump does not have enough
capacity to supply the front pump. When oil is
returned into the transmission case via the scv
return.
Connect properly and you will be pleasantly
shocked at the loader's new performance. It will
be faster and without shakes, moans, groans and
pump cavitation.
B&D, are you saying not to run a 12 row 9300 vacuum planter off the scv's? John deere set it up that way and ran for years, just wondering what your thoughts are!
