Anonymous-0
I recently put a rebuilt injectio pump on my 2020 and need to make sure it's timed correctly.
I put no. 1 cylinder on TDC, aligned up the flywheel using the timing pin, and aligned up the marks in the window on the pump. I've read that you need to install a plastic timing window to make sure the advance is correct. How do you do this unless you have some kind of timing light to strobe in the marks?
Also, who makes a tool to help with the umbrella seals?
