:?: Here is a terrible drawing of the wiring diagram:
http://img828.imageshack.us/img828/1632/14300806.png
This is an Allis WD45 that was converted to 12v negative ground by a previous owner. It then sat in their barn for 15+ years and mice ate the wiring. I bought it for scrap price, rewired it with a simple battery to coil to distributor circuit, changed the fluids and had it running in a couple of hours.
I've done the sheetmetal, body work, fluids, gaskets and paint. At this point. She's gorgeous. Now its time for a real wiring job. If I remove the generator from the circuit, the tractor starts and runs great, all the lights and the implement accessory light work, its just perfect!
The wiring on the generator and vreg were thankfully not eaten by mice, but I'm having trouble figuring out the circuit. There are no labels on the generator or vreg except for a single A stamped in the post coming out of the top of the generator.
As soon as I run a 10ga wire from what I believe is BAT to the discharge side of the amp gauge (the green wire), the wire starts spraying sparks, the amp gauge goes full discharge and I can't start the tractor.
With the green wire disconnected and the tractor running, I get about half a volt out of what I think is the BAT terminal to the negative battery post. From the positive post, I get -12.8 volts.
With my ohmmeter, I show continuity between all 3 terminals on the vreg, and both terminals on the generator to the negative post on the battery. I believe the entire generator circuit is somehow shorted to ground, and the reason for all the sparks is that the power is taking the easy route out across the amp gauge and going to ground at the generator.
Now that I've said all that, where do I start? I don't know if its just a polarity issue with the generator, if the generator/vreg armature is stuck, if the wiring is all messed up, or if the vreg is bad?
I'm about to give up, park it, toss a tarp over it, rip the generator out and drag it to a local Allis dealer...but I'd like to at least have a clue what to tell the poor guy at the service desk. And I'd also like to know what to expect on the repairs front. I don't need someone charging me to transfigure my whooptie-jigger if I just need a new vreg, or to jump a couple points on the terminals.
Anyone able to help out a nooby trying to rescue some old iron?
Edit:sorry about the lack of a hyperlink for the wiring disgram, it says my account is too new to post images or links.
