Swivel fitting for Winch??
John Pelland
New User
Can anyone tell me what fitting I should use to supply hydraulics to a winch clutch slave cylinder. At the end of winch shaft is a 1/8 NPTM tubing. I need some kind of swivel to put on there that will allow for the constant rotation of the shaft. To that swivel I will attach 1/8" copper line going to the master cylinder. Anyone got any ideas on what kind of fitting will allow for constant rotation? Thanks!
Similar fitting is on the variable speed drive on a Model K,F,F2 Gleaner combine, gear drive, not hydro. Check with an AGCO dealer for part number, or check a good hydraulic shop.
After giving you that advice, I"m having some second thoughts- unless I go out and look at the real combine!!
