parts for a IH 430 baler
Anonymous-0
Hey Im looking for the arm that adjusts the length of the bale for and IH 430. The machine is working great but the bales are inconsistant lengths because the teeth on this arm are worn off and slip. Does anyone have a parts machine that might have a good arm on it? Thanks
on my 430 arm doesn,t have teeth have a clamp which I adjust to handle length. most irreregular length is attributed to feeding of baler i have found. In brome I like a big windrow alf has to be less and dry is part of answer Bob
Ahh it just looked like there used to be very fine teeth. The arm has also been welded and needs to be rewelded or replaced still to help make it a bit more smooth. I will try to make the windrows a bit larger also and see how that goes. As for dry Ill keep my fingers crossed but Im in New England and not having very good luck with that. Thanks for the tips.
