folks...I broke my rear axle on my B414 and could use some advise how to get it all apart. Tire is off and bearing retainer is off on the axle tube. Broken shaft is out.
I understand that there is a large gear inside I need to remove a bolt before the remaining broken shaft will some out. I think I have removed all of the bolts for the 'under seat bit" since I do not know what it is called to access the gear. Anyone have details on this specific section on how to get to that gear!?
I need to get a manual obviously but by the time it gets to me when I order it....will take too long.
Also any leads on used part dealers online would be appreciated.
