I have 2 stuck wheel weight bolts and 1 stuck rim clamp bolt on the rear rims of my Farmall M. None of them are threaded, just rust locked. I drilled holes in each one on the edge so that penetrating oil could get to the seam, but I need to heat them too.
When heating something like this, do you heat the cast wheel to expand it off the bolt, or try to heat the bolt and let it cool down and hope it broke a little free?
Thanks
Thanks
