testing123
Rear tire on '55 Ford is 640 leaking. I don't have a way to transport the tire/wheel once I take it off ---it will have to be repaired in place--either the local implement dealer or DIY.
What is involved once I remove the outer wheel: how do you break down tthe bead? any special tools required? is is hard to remove the tube once the bead is broken? Would you replace or repair the tube?
Thanks--Jeff
Thanks--Jeff
