john deere 4020 injection pump timing
koen
10-08-2007 09:58:22
I have an early john deere 4020 and when starting, it only fires a few times and then it does nothing for over 20 sec. How can I check the injection timing or would it have another reason?
thanks,
Koen
koen
11-11-2007 07:45:47
 Re: john deere 4020 injection pump timing in reply to koen, 10-08-2007 09:58:22
third party image
third party image
do you mean this with part n°37 (picture 1)
The ball in the elbow falters now and again, could this be the cause?
I didn't found plastic trash in the valve housing.
koen
10-26-2007 12:55:34
ok thanks, I wil open the pump to check when I have more time, I'll let you know the results
Thanks
Koen
Bob
10-08-2007 13:51:45
How full is the fuel tank... is the level of the fuel higher than the IP?
I'm GUESSING the tank is less than 1/2 full, and there's a leak somewhere in the fuel system letting a little air in when it sits a while.
koen
10-09-2007 07:57:35
 Re: john deere 4020 injection pump timing in reply to Bob, 10-08-2007 13:51:45
the fuel level is indeed a lot lower than the pump, but it would be strange becouse I was riding the tractor when the engine stopped running(there was no special noise or something). I have checked the injecton pipes at the injector and there was no visible air coming out, only fuel. I also replaced the fuel filters (they were messy) but it changed nothing.
Bob
10-09-2007 08:32:47
 Re: john deere 4020 injection pump timing in reply to koen, 10-09-2007 07:57:35
If you have a Roosamaster "DB" pump, the plastic "governor damper ring" may be failing deep inside the pump.
This produces "coffee grounds looking" chunks that plug the pump's housing pressure regulating valve, preventing return fuel from leaving the pump, which shuts it down.
Does your pump look like the diagram? If so, Key #37 is the part I am referring to.
Third Party Image
Remove the valve from the pump, and check for plastic chunks jammed inside it.
If that's what you find, post back.
