Restoration & Repair Tips Board
Marvel Schebler Carb TSX 670 on Allis Chalmers D14
Chris Bonjour
07-23-2007 13:08:42
Does anyone have a blow up diagram of the Marvel Schebler TSX670 that goes on the Allis Chalmers D14?
Also, the carb was full of rust, any tricks or tips on how to clean it really good? Where can I get a Complete rebuild kit for it?
old
07-23-2007 15:17:10
 Re: Marvel Schebler Carb TSX 670 on Allis Chalmers D14 in reply to Chris Bonjour, 07-23-2007 13:08:42
AGCO if the first place to look for a kit, then this site and or value bilt. Any good kit will have an instuction sheet that will show you what the carb looks like apart. Now to clean it you need a bucket of a good carb cleaner like berry mans and also a couple cans of spray carb cleaner and compressed air. I also use a torch tip cleaner to rod out all the passage ways to make sure they are clean
chris bonjour
07-24-2007 05:42:18
 Re: Marvel Schebler Carb TSX 670 on Allis Chalmers D14 in reply to old, 07-23-2007 15:17:10
Thank you for the insight, it will be helpful. One more question. With the carb cleaner get rid of the rust and scale inside?
old
07-24-2007 08:43:31
 Re: Marvel Schebler Carb TSX 670 on Allis Chalmers D14 in reply to chris bonjour, 07-24-2007 05:42:18
One other thing. If you have an O'Reilly auto parts store close they will be able to get you a good brand of carb kit. I use them for all my carb stuff they sell a brand called Walker and they seem to be a good kit. I could probably even get you the kit number if you would like me to
Chris Bonjour
07-26-2007 05:33:15
 Re: Marvel Schebler Carb TSX 670 on Allis Chalmers D14 in reply to old, 07-24-2007 08:43:31
I would love to get the kit number from you. Thanks for your help.
old
07-26-2007 09:45:12
 Re: Marvel Schebler Carb TSX 670 on Allis Chalmers D14 in reply to Chris Bonjour, 07-26-2007 05:33:15
I just called the parts store and got that Walker kit number. Its 778-505. By the way this kit is the same kit that will fit the Ford 8N ford carbs. The neat thing about the M-S carbs is there is only 3 or 4 different size carbs other then the main jets in them so there is only 3 or 4 different kits. Shoot I have a Walker 778-505 kit sitting right here in the the computer desk
chris Bonjour
07-26-2007 10:06:38
 Re: Marvel Schebler Carb TSX 670 on Allis Chalmers D14 in reply to old, 07-26-2007 09:45:12
Thanks so much for the kit number.
old
07-26-2007 09:13:16
I'll call my local O'reillys and find out what that number is and post it here in a little while
old
07-24-2007 07:29:48
Well thats a yes, no or maybe thing. All depends on how bad it is and how long you let it sit in the cleaner. I've seen some that where so bad they couldn't be cleaned up and other that cleaned up just fine
